fallenone121's 1971 Datsun 240Z Build
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
fallenone121
Car: 1971 Datsun 240Z
Frankie Datsun is a 1971 Datsun 240Z project being performed by Charles Mcmillan (fallenone121).
With products purchased and priced from varied vendors including Otaku Garage and Jordan At Defined with labor performed by the efforts of the mechanics at Cals Toybox, bodywork and paintwill be done by Ryan Racine putting exterior to paint code Nissan BNR32 #TH1, and artistic detailing will be done by Art Guapo Solis.
The 1971 Datsun 240Z itself was an ebay buy for 2600$ which was based out of New York where it was picked up from its home outside Niagara Falls. Initially the name Frankie came from a joke by Cal about the car being a Frankenstein monster.
Build will be conducted over the course of two years (preferably) with purchases of parts where funds allows - and will be completed in sections when all required parts are purchased and is roughly estimated to be 60000$ in parts with 20000$ in labor as a rough estimate. Maybe it wont take that many hours for labor and maybe I can get deals on parts buuuuuuuuut estimates in the meantime are done for a retail market.
Right off the bat the 240Z was brought to Cal's shop to be inspected initially as the vehicle was stripped down of nonessential items to allow for a more thorough inspection for rust damage. Interior thoroughly stripped out and put into storage as stock engine, transmission, radiator, exhaust was sold off via craigslist allowing for a more thorough inspection of engine bay and interior for rust.
The build itself will be slow going initially as I purchase parts because I am a disabled veteran doing the build with part of my disability check.
Purchased August 2012 - during the trip home the exhaust fell off on the trailer requiring bungees to hold it in place to get it off.
Realizing how in depth rust COULD be on this car I smiled and started to strip it down almost immediately wanting to see the damage as I started doing research on parts.then was put into storage in December 2012 for winter covered up and readied to roll!
fallenone121
PURCHASES TO DATE:
AUGUST 2012
RB26 from 99 R34 that had a T88 Turbo on it
RB25 Bellhousing and 300ZX 5-Speed transmission came with engine
NOVEMBER 2012
SUSPENSION:
Bad Dog Swaybar Plates
EXTERIOR:
1974 240Z Console
Autometer Gauge Cage
1969 Corvette Brake Scoops
300ZX Hood Emblem
Datsun Competition Spec Side vent Hood Scoop
SOUND:
(REAR) Fusion CPFR6930 - 450w 6x9 3W
INTERIOR:
4" 11k 4 in 1 Tach
Luggage Riser Trim (NOS)
Speedhut 200mph Large Speedometer
Speedhut Fuel Level
Speedhut Boost
Speedhut Volt
AEM Wideband A/F (from a previous vehicle)
Speedhut EGT
Power Door Locks
Billet Window Winders
(2x) Cipher Auto 5 Point 3" Harness
Fiberglass Door Panels (with speaker pods)
Tomioka Racing Pro Series FPR
JANUARY 2013
INTERIOR:
Nismo Steering Wheel
BOSS Steering Hub
FEBRUARY 2013
SUSPENSION:
Q45 R200/230 rearend
Subaru Impreza steering rack
SOUND:
Vintage 6x9" Speaker Covers (Music Note)
INTERIOR:
Coated Items Ordered from Zeddsaver:
Door Clasp
Hood Hinge
Hood Clasp
Hatch Clasp
MARCH 2013
Ordered from Otaku Garage:
ENGINE:
Tomei Stroker Kit 2.8L (87.5 mm)
* Piston (Tomei)
* H Beam Rods (Tomei)
* Crank (Tomei)
** Added Option: Cooling Channel
Ordered from Defined Performance:
ENGINE:
ARP Main, Head, Rod Studs
ACL Rod & Main Bearings
Tomei Procams (Super High 280)
Tomei Type C Valve Spring & Retainer
Tomei Valve Guides
APRIL 2013
ENGINE:
Tomei High Perf Oil Pump
Tomei Intake & Exhaust Valves +1
Tomei Head gasket 87mm x 1.5mm (metal)
Tomei Oil Filler Cap
Nissan OEM metal gasket pack
Tomei Oil Pan Baffle
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
Oh yea! Welcome to NICO! This is going to be good. RB's takin over. lolz
:dance
fallenone121
Some pics of parts...
Including the hopeful future plate...
Or the Japanese plate ^_^
fallenone121
June & July Parts purchased:
91 Honda Civic Windshield Wiper Motor
Tomei Top Rail Fuel Pipe
Tomei Strengthened Timing Belt
Tomei Adjustable Cam Gears
Low Impedence 1200cc Injectors
Nismo N1 Water Pump
McKinney Motor/Trans Mounts *Semi Solid*
McKinney Rear Sump Oil 7 qt
ATI Performance Super Damper
McKinney Throttlecable & Bracket
Greddy Pulley Kit
Koyo Two Core Radiator R022352
Nissan Oil Squirters
Radium Engineering Coolant Overflow Tank
Derale Radiator Fan Shroud (4000 CFM) with Twin fan controller D16825 & D16788
Chevvy123
Car: 1995 240sx ka24(sold)
1972 240z (sold)
2004 G35 building a short block for tt upgrade
1996 240sx rb20 powered
How much did you source the RB26 for?
fallenone121
Chevvy, The RB26 I was able to pick up with RB25 bellhousing and 300ZX transmission for 5000$.
June 2013 Purchases:
A big thank you to Radium Engineering for helping with pricing - after talking to Dave Klocek - I decided to pull the trigger since it was part of my July purchase list anyway...
* Universal Radium Engineering Coolant overflow tank with attached swirlpot, 1.3 bar cap, and -6 AN connectors
* Walbro 400 | E85 rated | inline surge tank with frame mount and fully populated wiring harness for the system
July 2013 parts purchases
Nismo N1 Water Pump
Greddy Pulley Kit
Carbon Fiber Hood Pins
November 2013 Products purchased...
ST Suspension Swaybars
Energy Suspension Hyperflex Master Kit w/ Extra Prelube
Rear Trailing Arm Bushings - Inner Position
Rear Trailing Arm Bushings - Outer Position
Front Lower Ball Joint
Outter Tie Rod End Passenger Side (98 Subaru Impreza)
Outter Tie Rod End Driver Side (98 Subaru Impreza)
Fusion 6.5" Component Speakers (Front)
Hifonics 2000.4 Amp (Mid & High)
Lizardskin Ceramic Insulation (2 Gallon)
Lizardskin Sound Deadener (2 Gallon)
6 cans 8oz Eastwood Rust Incapsulator
6 cans 8oz Eastwood Frame Treatment
7" H4 Euro Headlight Conversion
55w (5000 Lumen) Hi/Low Xenon HID Kit
Cipher Auto Racing Seats (2x) w/ Brackets
Frame Stiffening Stage 2 Kit
TTT Roll Center Adjusters
TTT Tension Control Arms
TTT Spare Tire Cover
TTT Front Lower Control Arms
TTT Rear Lower Control Arms
BRE Rear Spoiler 50-1527
Fiberglass Air Dam 50-1612
Type 2 Side Skirt 50-1461
Rear Skirt 50-1470
Swaybar Endlinks
Top End Strut Tower Brace (Front)
AZC Front Diff Mount
AZC Mustache Bar
AZC Female Rod Ends
AZC Axles
AZC Steering Knuckle
AZC Brace w/ Doglegs
AZC Parking Brake
fallenone121
SALE! Classic Z Logo Floor Mats, Black, 70-8/74 240Z-260Z
SALE! Stainless Steel O.E. Design Coat Hanger Kit, 70-3/71 240Z
SALE! Z Logo Fender Cover
Chrome Factory Door Handle, Left, 70-78 240Z-260Z-280Z
Chrome Factory Door Handle, Right, 70-78 240Z-260Z-280Z
SALE! Clear Headlight Covers, 70-78 240Z-260Z-280Z
SALE! BRE Style Rear Spoiler, Fiberglass, Coupe, 70-78 240Z-260Z-280Z
ZG Works Style Front Air Dam, Fiberglass, 70-8/74 240Z-260Z
Type-2 Side Skirt Kit, 70-78 240Z-260Z-280Z Coupe
Fiberglass Rear Skirt, Classic Style, 70-78 240Z-260Z-280Z
Lock Pull Trim Ring, Black, 70-78 240Z-280Z
Billet Aluminum Z Logo Lock Pull Set, 70-78 240Z-260Z-280Z
Kick Panel, Right, 70-73 240Z
Fully Automatic Antenna, Chrome
Door Sill Vinyl Trim, Black, 70-8/74 240Z-260Z Coupe
SALE! Polished "Z" Logo Hood Release Knob, 70-73 240Z
Billet Aluminum Z Logo Turn Signal Knob, 70-78 240Z-260Z-280Z
Interior Vinyl Replacement Kit, Black, 70-73 240Z
Marker Light LED bulbs
Oil Drain Return
Battery Connectors
Another Glove Box Fairlady Z emblem
Carpet Extra Deep - Black with MegaMat to replace the fiber padding
Carpet Extra Deep - Black - 3 Yards purchased to do rear deck with
AZC Mustache Bar
AZC Female Rod Ends
AZC Axles
AZC Single Piston Parking Brake
Rear deck mat
Headliner, Pillar & Roof Rail Kit
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
$$$ :crazy:
You should go out and buy a kitchen sink just so you can say you got everything. :biggrin:
I have a receipt for every purchase I made for my car. I do not have the guts to add it up yet. Some day maybe...
Gord
fallenone121
Rotisserizing the Z to make things easier...
Sneak Peaks of my Powdercoating Accessorization:
Lighting Mods by Dave Irwin:
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
No doubt your doing it right. I saw vids of the LED modded lights before. They look pretty damn good. I might have to do that to my car one day. The floors should go pretty fast. You'll be going back together before you know it. :dblthumb:
Return to “Datsun Z Forum”
