Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Mon Jun 14, 2004 7:33 am
its a bit closer to the strut than a 7" 38mm, and the 38mm I believe I said was fine for an s14(they have more inner clearance than s13's) unfortunately wheny yuo're cutting things that closely, someones gotta guinea pig it(that'd be you..)
try it rim(no tire) first and see how much room you've got for tire...if its nearly none, go with a 215-45 or 40, if you got some room, use the 225-45/
-chet
