Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Sun Oct 19, 2003 4:55 am
"i still have a hint of body roll which i think is due to the sidewall being so big...?"
thats got nopthing top do with sidewall, its the chasis felxing or the suspension. Try running the tire a bit higher(35psi or so) that will help sidewall flex, but the body roll will remeain.
if anything, with stickier tires, body roll will increase with the transitional adhesion limit of the newer, stickier and stiffer tire...
ST sway bars do a good job of limiting body roll, but its not eliminated(nor do yo want it to be)
I'll quote dennis(Q45tech):"pick springs that you want to do 75% of your objective, then use sway bars for the rest"
-chet
