Yep, I am a canuck, i have been meaning to put some pics of my Lady on here but the quality is too high, here is a link to see 6 pics of my 1991 Fairlady Z TT.
http://www.facebook.com/media/set/?set= ... 35c9ff844a
Well I hope the seals are not blown, but if they are this summer is when it will be in the shop once again since the race clutch install. I have been reading many posts from all over and i stumbled upon this possibility that i intend to explore. I should have mentioned it in an earlier post. The car operates at 85 degrees (idle and while driving) it has shims in the back of the hood to lift it for more air flow, installed in japan. Oil used: 5w-30 royal purple with a lucas oil conditioner. The car has no coolant loss but when I run it on the hwy as i excelerate beyond 110 kmh the temp gauge goes up with the speed of the car, (not necessarily the rpm) faulty gage perhaps. as I approach 140-175 kmh the temp goes up to 100-115 degrees. as i decelerate the temperature gauge goes back down to 85. Its like the temp follows the speed of the car and how hard the engine is working. The car doesn't overheat when you pull over to the side of the road. really strange. anyhow i have read that people are getting great results by swapping from 5w-30 to a more viscous oil thats good in cold and hot conditions and is extremely resistant to thermal breakdown and the oil becoming too thin. so I ordered some Eneos 0w-50 oil. the people that put it in there car had brand new rebuilds new turbos, everything and the smoke was coming out of the tail pipes like mad, the charge pipes where loaded with oil and the Bov's were spitting oil. I am thinking that the condition mentioned above, the overheating of my oil broke it down to the point that it is like water and is passing by seals etc. It sounds hokey but as soon as a Greddy 0w-50 or Eneos 0w-50 was put in the car, no smoke no oil in the charge pipes etc. I am going to try it when the oil gets here in 4 days to see if it changes anything after cleaning the charge pipes and Bov's. The oil is rated for the engine so it can't hurt. The Temperatures up here range from 50 degrees in the spring to about 85-90 degrees in the peak months of the summer. It's the prairies, its flat and either windy and cold or hot as hell. Well the sort of mild hell you can expect living in Canada with such temperature extremes. Ironically, I was actually top of my class in power Mechanics 4th year and was scouted to work for Bristiol Aerospace or Jaguar as a Mechanic. My family hated the Idea, I listened to em like a fool and tried to become a lawer. I hated that and ended up starting my own Company and am a Journeyman Bricklayer. I build brick Chimney's for a living, of all things. and I sweep em in the winter. keeps me hopping for sure. However, by the prices they want up here to pull a motor $3500.00 repair anything on it $3000.00 to $6500.00 to change a head gaset Turbo seals, run a series of tests and put it back in the car. I am thinking it's time to set up the cherry picker and pull my own engine. I have every tool imaginable, I have a digital manual with every damned nuance of all the systems of the car in it. what I lack is the time to start rebuilding motors. This particular engine was rebuilt 50,000 kms ago. I guess this is why i am suprised that seals could be the problem. I guess anything can happen with performance machines. Let me know what you think of the 0w-50 concept. I will be pulling the charge pipes and Bov's to clean em. I am hoping I can make eye contact with the turbo props and check em for any play or etcetera. Thanks for the warm welcome! cheers
