blmbmj »
https://forums.nicoclub.com/blmbmj-u261503.html
Fri Feb 12, 2016 12:51 pm
INJS - Injection Service
105,000 Mile Service includes:
Inspect A/C system, cruise control, axles and boots, brake lines, drive belts, exhaust system and heatshield and lights;
Inspect steering gear and linkage, suspension components, tie rods and rod ends;
Check fluid levels of transmission, brake reservoir, engine coolant, power steering and washers;
Top off fluid as needed;
Replace: air cleaner filter, wiper blades, spark plugs;
Replace engine oil filter and engine oil;
Rotate tires, set tire pressures and inspect brake pads/shoes and rotors/drums
COST: $350.60 + $45 because of the CVT
So no, it would NOT include changing out the transmission fluid, which I have to do every 60K miles, otherwise I go into "Limp Mode". That runs $225.00
I think those prices are ridiculous, given what you have written and will absolutely go shopping. Somebody in Northeast Ohio will be cheaper than this.
Thanks!!
