Faint squeaking noise.
minlow88
Car: 93' 300z big piece of N/A
08' altima coupe
88' 4x4 s10
82' 280zx
at idle, up to 2600 it goes away, gets louder 2000-2200. Sounds like its coming from under the intake manifold. Maybe a lifter going bad? not pumping up enough oil? Its getting worse. It was only idle-1100. And it would go away when warm. It was only doing it when cold, 2 days ago. Now its all the time. It started about a week ago. I thought it was the waterpump. Sound like under the intake manifold about halfway down.
Any ideas? Oil is fresh, probly got 1000miles since changed.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
What's your oil pressure reading? The only moving parts under the intake manifold are
1. The cams, which would be about where you are describing
2. Lifters, which normally start to "tick" as opposed to squeaking
3. Pistons, which wouldn't squeak
4. Rods/bearings, which would be more of a "bottom end" sound
5. Crank. Same as above.
Take a video, post it up, and we'll try to narrow it down. You're sure it's not coming from the front of the engine?
minlow88
08' altima coupe
88' 4x4 s10
82' 280zx
possitive its not in the front. I have had this topend torn apart a few times.everything seems good. I even pulled off my clutch fan so I could quite it down to find it better. An injector wouldent ever make a squeaking would it?
minlow88
08' altima coupe
88' 4x4 s10
82' 280zx
Ok. Finally got some time to mess with the car.
The squeaking is for sure coming from the clutch assembly. And I have a leak. Im thinking its the rear main.
So question is..What would the squeaking be?
Throwout or pilot bearing?
those are the only things I can think of that would squeak in that region...
Ace2cool
You got it. Mainly the throwout bearing.
minlow88
08' altima coupe
88' 4x4 s10
82' 280zx
sweet thanks ace.. Thats what I was thinking. I have a 9 day vacation starting tuesday.
Gonna pull the motor and do a timing belt, pan gasket, rear seal, maybe a whole new clutch. and whatever else pops up in the process. I think i may even paint my transmission red lol. :chuckle:
es.biggs
Car: 1990 300ZX 5sp NA
haha have fun cleaning it. $10 says it's not your pilot bearing. Shoot, if you have a bad pilot bearing you can have my car!
