my sticker expired march o3 i didnt go to try and pass emissions then because my car was accelerating poorly due to the maf. i had a blitz Stainless filter on it but i noticed that the stock airbox helped it run smoother.
when the old maf went dead and the enginge wouldnt start was the only time the check engine light came on. i got the new maf, then i reset the ecu after i messed with the distributor.
then i got another maf from a friend and it ran fine...for about an hour, and then ran like crap again. started messing with ignition timing (distributor-turned clockwise) reset ecu and it helped a little. went to try and pass emissions and it failed:
high spd HC limit: 132 - read-> 119 P CO limit: 0.73 - read-> 1.26 F NOx limit: 945 - read-> 2051 F low spdHC limit: 136 - read-> 152 F CO limit: 0.76 - read-> 1.91 F NOx limit: 1045 - read-> 2258 F
so i changed the O2 sensor bc it was consuming a lot of gas(barely 200 mi to tank, usually get aroung 380mi), it bogged at 2500 and higher rpms, somtimes at idle during warm up. reset ecu. the sensor did help when i tested emissions again BUT it failed the nox again:
high spd HC limit: 132 - read-> 46 P CO limit: 0.73 - read-> .20 P NOx limit: 945 - read-> 1606 F low spdHC limit: 136 - read-> 90 P CO limit: 0.76 - read-> .30 PNOx limit: 1045 - read-> 2644F
yesterday i messed with distributor and the screw at the back of the intake manifold near firewall (iav screw??) resest ecu. and it feels like it used to when i got the car a year ago, revvs smooth w/o hesitation.
the guy who ran the car the second time for the test said it was either the EGR sys or the Cat Convt. i havent checked for codes because this whole time the check engine light never came on.
help pls
