FAILED SMOG TEST PLEASE HELP!
jedbimcdb
Car: Nissan Altima 2003 4 cyl
Here are my results
FAULT CODES
P0725 and P0335
%CO2
14.4 AT 15 MPH
14.5 AT 25 MPH
%O2
0.2 AT 15 MPH
0.2 AT 25 MPH
HC (PPM)
MAX 55 / MEAS 50 AT 15 MPH
MAX 39 / MEAS 53 AT 25 MPH
CO (%)
MAX 0.50 / MEAS 0.53 AT 15 MPH
MAX 0.48 / MEAS 0.53 AT 25 MPH
NO (PPM)
MAX 437 / MEAS 2059 AT 15 MPH
MAX 724 / MEAS 1964 AT 25 MPH
Please tell me possible solutions and estimates
Buckshot
you need a crank sensor and that will take care of your problem. probably have long crank time also.it is located in the back of engine on left side by the motor mount would suggest original equipment if possibly.make sure you look in the connector for oil and clean it out if possible.parts should be about 70 dollars and if you have a auto zone have them clear like and drive it about 1/2 hr on highway should take care of it...
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
What he said. I am a little concerned with how high the NOX numbers are, but that could be a side effect of the lack of a working crank position sensor.
