dkdeleon68 wrote:.but also check injectors a loose or cracked injector will make your car run rich and running rich you will fail NOX.
WRONG!!!! Bad info
A rich fuel condition will have a completely opposite effect. The excess fuel will cool the cyl and bring NOx down. NOx requires 2 things to happen high cyl temp [2500 degrees] and pressure.
IT looks like you have a couple things going on. I am suspicious of 2 things with the high Hc and Co your car may or may not be running a little rich but I say probably not since your NOx are so high. I suspect your cat is bad, but an O2 check would be a good idea. For your NOx I suspect you also have an EGR issue going on. Check for codes see if you got any stored in the ECM. If so post those back. But also take a look at the little rubber hose under your BPT see if it is extreamly soft almost to a mushy point if so replace it also if it is burned through. If you find that and fix it be aware it wont fix the other 2 gases that failed.
Here is the EGR and BPT the BPT is the higher disc in the picture and has a hose right underneath it. The BPT is the one with 2 bolts in the top of it.
