Didderson wrote:Why not correct your timing? You might want to reset the ecu and run 93 octane for the check.Clean that MAF sensor and make sure your grounds and maf wiring are solid.
Idk what else to say but KA's are dirty whore motors even when they run right. Imo my sr with a straight pipe smells the same as my friend w a stock KAE
I think it's offensive that they not only fail you, but LABEL you as a gross polluter as if its a felony crime or something. Man CA, give your residents a break.
I don't see what I'm failing to explain here. When they put my Vin in the computer it comes up as the emissions for the KA24E it also tells the Smog Tech that the timing is suppose to be 15 degrees. I can have a +3 or -3 then stock timing. KA24DE timing is 20degrees. Hence I cant have it 5 degrees advanced for the test because I'll fail for that.
Also theses no 93octane in California (unless your at a raceway) 91 is the highest and since I'm retarding my timing higher octane technically should be hurting my emissions because is burns slower therefore having a chance of not burning completely which is what I've read can cause High HC and CO emissions....
I got a new o2 sensor, and am going to refill my tank with 87 in a couple days. Possibly seafoam it aswell. Any other suggestions or ideas???
