ob1 »
https://forums.nicoclub.com/ob1-u58264.html
Sat Sep 01, 2007 1:47 pm
First check your ecm, it is located in the passanger side kick panel . Unbolt the ecm and locate the small screw on the side of it, with the ignition in the on position car not started turn screw all the way one direction then turn it all the way other direction. Light will begin to flash the code that is in the ecm. 55 means ok. For example you count the flashes, it will show first 5 flashes then pause then 5 more to indicate the next numbers. I can tell you the codes and what they mean if you have any.105 is the egr solnoid I had this code in for a while and still passed I just fooled the ecu that it was really there I used a relay in place of the egr solnoid but I think if your check engine lite was on the techncian would have failed you for that. High N O X usually indicates that egr or cat is not functioning proporly heat up the cat really good before you get to smog staition by driving around car about 30mins prior to test. See if your egr is functional put your finger underneath egr rev engine to 2000 rpm and see if you can feel the egr lift, if it does egr is functioning.
