AZhitman wrote:Welcome aboard!
I'll make this REAL easy for you - DO NOT try to "piecemeal" this job. Buy the 5-lug hub conversion made by Ichiba, available from our sponsors, cheaper than you can collect all the junkyard parts. (Plus, you get new hubs / bearings, not junkyard garbage.)
Then, buy your Z32 calipers used from the Classifieds here, stainless lines from one of our sponsors (lots to choose from), Z32 rotors, and new pads. You're DONE!
p.s. No need to get crazy with "vented" rear rotors, you're talking about a lot more modification, and the 240 doesn't need that kind of rear brake action.... Focus on the fronts, and get tires that will handle your new braking power.
were you reffering to the front and rear? z32 all around? im under the impression that s14 rears are needed, and z32's wont work on the rear without a lot of modding. also, i read that the rear rotors on an s13 arent vented (no fins, just solid metal im assuming) whereas the s14 and z32 are, and also utilize bigger calipers. if you meant z32 all around and ive been misinformed then the comment about not needing vented rotors in the rear is what threw me off...i feel like a dumb ***...seriously.
