vasponger »
https://forums.nicoclub.com/vasponger-u21472.html
Wed Mar 29, 2006 4:50 am
[QUOTE=driftking666sk]the bellows he is talking about are the rubber boots coming off the end of the rack on each side where your tie rods come out. If the bellows are bad that will make the rack leak at the bellows, if the rack is also leaking i would replace the whole unit. When you buy a rack assembly you get your rack with new bellows, inner tie rod ends etc. 240s are very easy to do a rack on. Good luck BTW they might be tryin to bone you saying the rack is leaking beacause if the bellows are bad that will make it look like a rack leak. You can get bellow kits and the will fit aftrermarket tie rods. It could also be lines and they are tryin to sell you a whole rack job[/QUOTE
i hope theyre just being shady, i heard from a couple people that they do that kind of stuff. they also said i had 3 exhaust leaks, but somehow i passses CO emissions not even a year ago with the same "leaks"
how much would a whole rack run, ive been looking but no luck. and s14's never show up in our junkyard so.
