OnTheRoadAgain wrote:1. My 91 Q45 failed emissions for "No" it was only slightly above the spec.
No is NO=Nitrous oxide. Do you have any ECU codes? Have you changed your O2 sensors lately or ever? Mileage? If you've never done this new O2 sensors will reduce your emissions and pay for themselves in a few months with the improved gas mileage.
Is your engine running/idling a little bit rough? You could easily have a marginal or bad fuel injector or two. Ohming injectors is a simple DIY and you may as well check the KS while you're there. Check the ECU codes and ohm the injectors and you should have a pretty good idea of why you're failing emissions. Let us know what you find.
