Failed emissons on a stock KA any ideas?
Clearalbino
Results are as followed
HC-1.49Allowed-.80
CO-58.55Allowed-12.00
I've replaced my spark plugs,wires, rotor, cap, o2 sensor
All the car has on it is a cold air intake and cat back exhaust
I've inspected the spark plugs and o2 sensor and they have carbon build up.
Any idea on what it could be?
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
Set your distributor to 20BTDC. You may be off a tad. Also check all your vacuum lines. Run an ecu diagnostic to see if any smog devices failed.
MikeMurphy
Car: Guess
Switching up the coolant temp. sensor helped me quite a bit. Mine was on the fritz.
I would have to dig up my papers to give you a numerical improvement. I had passed by less than 1% on one of the catagories. I then put another 20,000 km on it and the only thing I changed was the coolant temp sensor and it chopped some of my emissions by 70%. Its really only a $30 that should help you anyways.
If you really want me to dig up my papers do let me know.
