rbsileighty wrote:Depends on if you failed due to Nox or if your hydrocarbon count went up... higher hydrocarbon would make adding fuel a bad idea for obvious reasons. I think the larger gap plug will give you a more complete combustion at low engine speeds, so yes I do think it's a good idea.
What are your operating conditions at these 2 load levels (RPM, boost etc). If you are boosting that would hurt your Nox due to added pressure... consider diconnecting your actuator from the flapper valve so that the wastegates are always open => no boost.
Your temps couldn't be to bad at 15mph... i'd pull the added fuel back out, but that's just me.
Since your HC's weren't bad before... this probably isn't to big of a factor... but how fresh is your O2 sensor?
Your best bet for lowering the Nox would be if you could temp install some form of EGR on the car... then you'd probably be set...
Modified by rbsileighty at 5:12 PM 11/16/2005
Ok, did some things, got the re-test done.
First, I retarded the timing back to 17ish degree, coming from 21 degrees.
Second, I changed out the 6-heat range NGK coppers to a 7-heat range NGK copper plug. Did an oil change, flushed coolant, and made sure the fuel was dead on.
Third, I added a pound of fuel from stock at idle. This was done to richen out the motor, so there is no detonation, which would result in higher cylinder temps.
I failed the 25mph test by reading a 947 for NOx. Allowed is 945. So I failed by 2 ppm. WOW.
But on the 15mph test, I failed with a 1518 for NOx, allowed is 1045 ppm. So I don't know what to do now.
The RB26 has no EGR stuff for the motor, it is "EGRless" from the factory. So yeah, don't know what to do there. There was 0 boost being created during the test to the best of my knowledge. So I don't think the boost is a factor here.
Well, I think I am gonna give up and "pay" my way for emissions. Sorry I can't go into more detail lol.......
Unless anyone else has an idea here, then I am done lol......
