Passed all tests except HC at idle. 324 was my number 220 is max allowable.
I pulled a plug and it looked fine.
Anybody got ideas?
I wouldn't think the deleted EGR is part of the equation, since it doesn't open at idle anyway... Has it passed emissions with this setup in the past?LEMHEAD16 wrote:It's just Idle HC thats killing me. 235,000 miles on the car so I wouldn't doubt that the cats are bad. It does have a full custom exhaust that deleted the EGR, but I don't think that is what is causing it.
The Q is actually suffering with today's 93 octane crap gas vs. what was available in 1988 when it was designed. Burning a lower octane fuel will cause detonation, and when that's detected by the knock sensors - put the ECU in a "safe mode" in terms of the timing advance - causing it to enrich the fuel mixture. So unfortunately that would make a rich condition worse...GSUjinih wrote:I might try running 89 octane fuel instead of premium. I doubt in factory trim these cars are taking full advantage of that extra octane (93 octane in GA) and having a slightly incomplete burn, but not enough to show up on the plugs. Also, they sell this stuff at the parts store that they say you will pass emissions or your money back!
LEMHEAD16 wrote:Car runs great.
All other numbers are in the passing zone by large margins. It's just Idle HC thats killing me. 235,000 miles on the car so I wouldn't doubt that the cats are bad. It does have a full custom exhaust that deleted the EGR, but I don't think that is what is causing it.
Not true, at lower throttle and RPM you do not need this extra octane. I was averaging 22MPG with 50/50 mixed driving on 93 octane fuel. I have been using 89 octane fuel for the last few tanks (due to the crazy price hike from midgrade to premium) and actual saw gas mileage go up to 23MPG. This was using the same gas station at the same pump, even at about the same time of day with nearly identical trips. I will log my ignition timing and check to see if it is backing off at all.Q451990 wrote:The Q is actually suffering with today's 93 octane crap gas vs. what was available in 1988 when it was designed. Burning a lower octane fuel will cause detonation, and when that's detected by the knock sensors - put the ECU in a "safe mode" in terms of the timing advance - causing it to enrich the fuel mixture. So unfortunately that would make a rich condition worse...GSUjinih wrote:I might try running 89 octane fuel instead of premium. I doubt in factory trim these cars are taking full advantage of that extra octane (93 octane in GA) and having a slightly incomplete burn, but not enough to show up on the plugs. Also, they sell this stuff at the parts store that they say you will pass emissions or your money back!
This brings up another thought... if the knock sensors are not functioning, the ECU is already using the "safe" timing map, so that might be something to check.
Heath
If you think 93 octane is crap gas then you must be getting your gas from the wrong station! Do they not sell JWT and NICO ECUs that bump up the timing and run totally fine off 91 octane in most conditions? I still am not sold on the car enriching the fuel mixture based on knock sensor input.Q451990 wrote:The Q is actually suffering with today's 93 octane crap gas vs. what was available in 1988 when it was designed. Burning a lower octane fuel will cause detonation, and when that's detected by the knock sensors - put the ECU in a "safe mode" in terms of the timing advance - causing it to enrich the fuel mixture. So unfortunately that would make a rich condition worse...GSUjinih wrote:I might try running 89 octane fuel instead of premium. I doubt in factory trim these cars are taking full advantage of that extra octane (93 octane in GA) and having a slightly incomplete burn, but not enough to show up on the plugs. Also, they sell this stuff at the parts store that they say you will pass emissions or your money back!
Heath
Really? Damn! Around my way 87 is $3.17 (today) & 92/3 is $3.43. The extra $.26 is totally worth the peace of mind I get . I don't even miss it.GSUjinih wrote:Around here there is more than a 10 cent difference between midgrade and premium, sometimes up to 40 cents difference. My advice was actually for the OP.
