failed emissions
bonsi
Car: Nissan 240sx
failed emissions 1st time did not leave car running the HC limit is 01.20I had 02.36, second time left car running oil change new air filter again I failed the HC limit it was higher 02.62 Wha tdo I do
180fan
Car: 89 fastback
your numbers for all measured emissions?
NISTECH
Scan or copy the emission test results and post them.
bonsi
Car: Nissan 240sx
1st time LIMITHC 02.36 01.20CO 013.33 020.00NOx 00.49 02.50CO2 301.66 NAdidn't keep running kept turning off 1.5 hrs
2nd timeHC 02.62CO 011.30NOx 01.12CO2 265.23ran for 30 miles and kept running until test
NISTECH
sounds like by your numbers a possible bad cap, wires or plugs. Your numbers indicate you are not burning all your fuel. the rest of your numbers indicate combustion is occuring and your not getting to much fuel as your co numbers are in the passing range. Be aware co MAY go up when you get the unburnt fuel condition taken care of.
