DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Thu Jan 20, 2005 5:42 pm
Of all the blind solutions the cat is probably the most expensive option. Save that one for last or at least till a little more is known.Definitely looks rich still. The extra gas is why HC is high, and also by CO is high, since there's not enough O2 to create CO2, so CO gets created in the burn. Also, slow rev is another sign.If you're sure it's not misfiring then it could be an injector leak, a bad O2, or a bad temp sensor/connector, just to name a few. I don't think a bad O2 by itself could cause a failure, but I'm not certain. You could measure the voltage and see if it dances up and down past .45V.
