InsanityInc »
https://forums.nicoclub.com/insanityinc-u19073.html
Fri Sep 30, 2005 12:50 pm
that's a bit more than barely.
But, your CO is high, which means you're running rich. If your cams were the problem, only HC would be high.
So, my guess would be either that:
Your TPS needs adjustment (pretty likely)Your O2 sensor is dead (semi-likely)Your Coolant Temperature Sensor is dead(very likely)
O2 sensors and CTSes are cheap to replace, and adjusting the TPS is easy. So, do those and you should be good.
