Failed Emission!!! help!!
DrifterXRPS13
Car: 1993 Acura Integra LS, 1998 Nissan 240SX SE 5sp. KA-T,2004 Honda CBR 600RR, 2005 Suzuki GSX-R 600, 2013 Harley Davidson Iron 883, 2014 BMW S1000RR
i failed my emission about four five months ago and have not had a chance to figure out what's wrong with it, when i asked for help they wanted to see my results but my mother had thrown them out, but no i finally got a copy of them and here they are
Standards Readings
Hydrocarbons: .80 .88
Carbon Monoxide: 15.0 29.1
my car is an 89 fastaback se, 5 spd, mainly stock with an air filter and aiv removal(after i failed) haven't replace my plugs, cap, rotor, wires, o2 sensor, please help me before i take it to the shop. thank u.
180fan
Car: 89 fastback
Try the tune up first and get a pre-test. See what happens. It would be alot more help to have the actual numbers though, that'd point the rest of us in a better direction than stabbing in the dark. But for sure try the tune up.
s13sr20chris
agreed. what was the co2?
DrifterXRPS13
i did post the readings, the standards for hydrocarbons are .80, my car read .88 and the standards for carbon monoxide is 15.0 and my car read 29.1, thanks for the help
navysnail
there is usually 4 readins: co, hydrocarbons, co2, and NOx
from the 2 that you posted, the hydrocarbons are too high, meaning that you are running rich, replace everything that you mentioned above, including o2 sensor and that should get you to pass if your only .08 over
DrifterXRPS13
thanks 240kid, the reason i only posted two are because that's the only ones that matter, i don't get a pass/fail on the other two, they come up as n/a....btw off topic, hows the brm exhaust?
navysnail
hmm, wierd, maby they dont check those in your area
i love the brm exhaust, fit perfectly and sounds just the way i would like it to.it makes a noticable increase in power delivery, the powerband is more linear
s13sr20chris
i was wondering the co2 just because its an indicator of complete combustion(though you must not be having that). i guess i just like to look at the bigger picture. i know folks who say a new cat and a gallon of denatured alcohol in the tank during the test will pass just about anything.
Julio Bro!
Car: 1993 240SX SE, manual transmission, Stillen intake & strut bar, Magnaflow cat + custom cat-back, NISMO sus
I ran into a similar problem today, emissions are tested at high and low rpms; I didn't pass low rpms. I don't know how the standard units are but these are my numbers:
HC = 405 (need 300 to pass)
CO = 2.27 (need 1.50 to pass)
I removed my PARC valve a few months ago and I know this works at low rpms and decceleration; could this be the problem?
I already replaced spark plugs, oxygen sensor, temp sensor, cleaned the idle control valve, and MAF is fine.
Suggestions?
s13sr20chris
yes, the pair valve is important for low rpm emmissions. it injects air into the cat to help it.
Julio Bro!
Today I reinstalled the AIV so I expect to pass tomorrow at the emissions test.
DAEDALUS
Car: 1990 Infiniti Q45
Make sure the engine is fully warmed up. The cats don't do anything if they're cold. O2 needs to be hot too, but not as much as the cats. In case the valve doesn't do it, and ssuming the cats are hot and in good shape and everything else is working, your numbers would suggest that the car's running rich.
Julio Bro!
As I explained on my "Truth..." post, this engine runs on the rich side and the AIV helps to counter some of that. On latter engines the ECU was programed for a leaner mix and thus the AIV was not needed.
I hope my numbers go dow; I'll inform what happened.
