cdndub »
https://forums.nicoclub.com/cdndub-u122240.html
Sun Dec 14, 2008 8:50 am
I picked up a 1992 Q45 from a long time enthusiast earlier this year for an excellent price, I have never owned a vehicle with such a perfect maintenance record/history. Same owner from 66k km's to 310k km's with records of all the work he'd done.
The car ran well when I picked it up, however i quickly became a victim of failed valve cover sealant leaking oil into the plug galleys. I decided to change the plugs and after avidly reading through the forums here paid the money for a set of the OEM recommended ones along with several new hoses while everything was apart.
This teporairly fixed a misfire condition and hesitation below 2k rpm, and the car regained some of its lost power.
Sadly this problem keeps rearing its head and I've finally ordered a consult cable and software as I give up on being able to troubleshoot it without.
However now that i've rambled about the history of how I came to this point My actual question for all the experts here is around a failure that occured after doing the above fixes.
After suspecting the alternator was failing for a few weeks and checking it with a DVM <both at idle and at 3-4k> for both DC volts and AC volts the problem finally came to a head and it must have had failing diodes in the rectifier that only showed up after it had warmed up etc.
In the end it turned out the diodes completely failed, it wouldnt charge at idle and the car stalled out on my wife a few blocks from home, however when restarted it would charge but at 18-19volts at 2k rpm.
Enough overvoltage that it boiled and slightly melted the battery which probably further compounded the problem by dripping battery acid down onto the alternator.
I spent $350 on a Bosch Reman of an OEM Nissan alternator which appears to be good quality.
I also installed an Optima Red Top at the same time as I have long despised wet cell batteries for all the rust/damage they cause under the hood over time.
Charging system is now good, 12.8-13volts at 500rpm with the car running, 14volts as soon as it comes up over 650-800rpm
But the misfire has come back, I changed out the MAF, checked all the vacuum lines, injectors etc and with the MAF change it now runs much smoother. I also pulled the codes and had a code 12 and 13 show up
I've already gone through all the electrical connectors under the hood once with DeoxIT D100 and then DeoxIT Sheild to clean and then preserve all the connections for the injectors, sensors etc.
Now that the cooler weather has come to roost the A/C display has suddenly started turning itself off once the car warms up I'm guessing there is a bad solder joint or failing capacitor etc inside that is now heat sensitive.
However that problem coupled with the overvoltage from the alternator I'm starting to wonder if it may have damaged the FCPU or fuel pump or things like the AC controls.
I'm wondering if anyone knows how well protected the electronics are in the Q from things like this.
I'm going to jumper the FCPU and check to see if i've just lost the low range and will T in a Fuel pressure gauge and check that as well, the pump is quiet and was replaced fairly recently according to the documents i've got from the previous owner. I think its now on its 3rd or 4th pump since it was new.
Sorry for the wordy/convoluted post just thought i'd fill in some of the background info.
Dave
