fail safe on the cluch?
supercharger240
Car: 1992 240sx hatchback
I have been driving for a little while now and i have a nessin 240sx with manuel transmusion. when i try to open her up she stops at 120 mph now i only am doing 4500rpm and i red line at 8000rpm. why is this happening? and how can i stop it?
Ligouri Rd
Car: '96 Nissan 240SX
Ah, the ole 125mph (or so) fuel cut. I believe the only solution is to clip the vehicle speed sensor where it goes into the ecu. I am not sure what the ramifications on the speedometer are.
silencer.1
Car: women, my car, paintball
It's actually a 115mph fuel cut-off to keep the kiddos from going too fast. If the fuel cut-off is disabled (not hard) then the 5th gear speed limiter kicks in at 5500rpm. Also, the redline is not 8000rpm, it's 6500rpm. Yes the tach goes that high, but if it ever did, you would float all the valves and blow the engine.
I personally do not recommend you remove the speed limiter. The only reason you should need to remove it is in the case of a high horsepower car at the drag strip in which your trap speed is approaching fuel cut-off. There is no reason to be doing that kind of speed on a public road.
navysnail
besides, at that point you are exeeding the speed rating of the stock tires, which is a bad idea in itself.
ArcherV20
Car: 1995 240SX
Maybe getting some overnight parts from japan. A thread about speeding, in which the user does not know when his own car is topping out, or his own redline. With a thread title involving the clutch. Hmm.
