Faded/Yellowing OEM Paint Protection and TPMS Question...
mpbclutch33
Car: 2008 Altima Coupe 3.5L, 6-speed, Radiant Silver.
The square OEM paint protection on the rear quarters looks to be fading/yellowing with time. Anything I can do to fix this?
Also, the last couple times I have been on the highway, my TPMS would flash for about a minute or two then stay on for about 5 mins. and then go off. I have checked the tire pressure and they are all at 32 psi. Whats the deal?
Throckmorton
Car: 2007 Altima
No idea about the paint protection.
TPMS?
Are you checking the tire pressure when the tires are cold, or after they have warmed up after you have driven the car for a while?
Try this. Check your tire pressure when the tires are cold. I’m going to make a wild guess and say that you don’t have an air compressor at home, so you check the tire pressure after the TPMS light illuminates, which means that you have to drive somewhere to put air in your tires.
Here is the deal. During the extended cold weather you are having in Maryland, your tires have become low on air, lower than 32PSI cold. Tires naturally lose air in cold weather.
According to Edmunds.com, every 10-degree drop in ambient temperature results in a one-psi reduction in tire pressure.
mpbclutch33
I understand all that, but the light is not on for about the first 20 mins of driving then comes on for a couple mins and then goes off.
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
Take those stickers off the rear panel. Easy as that
xfactor0707
Car: Nissan Altima Coupe 2.5s
SHIFT_COUPE wrote:Take those stickers off the rear panel. Easy as that
