faded rims...
Chimera
Car: '97 240sUx, slow as hell.
i bought my '97 240 in april and i noticed ever since i bought it that the rims were faded, its silver, but looks like there are huge oil spots and discoloration....anybody know of any cleaning solution/chemical that can clean these blotches right off?
Eddie
Car: 1995 240sx se
My 95 wheels look just like that. Sometimes I will wax them with maguires scratch-x followed by a caranuba finish and it helps them not look as faded.
With the scratch-x I can get rid of those oil looking spots, but it does take some elbow grease.
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
my wheels looked like that when i bought the car. Instead of trying to restore them, I just painted them graphite black. It looked to me like the clear coat was going bad, if thats the case, i think you'd have to sand it down and recoat it.
AmIdYfReAk
Car: 1990 240SX Coupe
i kinda agree with Bronze, there looks to be some corrosion on the rims them selfs.
if you take a look at the Standard rim cleaner at some stores and give them hell, you will be able to clean them. but keeping them that way might be a problem.
pmkls2
Car: 1990 240SX Fastback
thats a common prob on all aluminum wheels and the cause is the clearcoat is cracked allowing oxidation to occur on the aluminum under the coating there are a lot of things you can do to make them look better but the only complete fix is refinishing or new wheels
nismo521
Car: 1993 Nissan 240SX HB
You can use aircraft remover to strip the old clearcoat (this stuff doesn't play around, so don't leave the wheels on the car), then scuff up the aluminum w/ a red 3M pad and put on some duplicolor wheel clearcoat. Should look good as new.
pmkls2
yeah that reminds me where can you find that stuff ?
nismo521
Most auto parts stores carry it, in the paint section.
pmkls2
aha, I never go to parts stores, just tell my parts guys to order me stuff lol
Chingon
Car: 1991 and 1992 hatchbacks
mother's wheel polish 6 bux.
navysnail
you should see my one rear left wheel, it looks like someone poured acid on it, and then 15 minutes later realized that it wasnt water and washed it off, all the clear coat is gone and its bad, luckly im getting some used '92 alloy's though
