spartan40 »
https://forums.nicoclub.com/spartan40-u70233.html
Sat Jul 07, 2007 12:36 pm
Hello I am having trouble trying to get my 90 240sx to run. I have checked the ecu and it keeps telling me code 55. I have checked wires, plugs, distributor, and the iac/acc. Nothing seems to be wrong with these. It ran fine for a while, then i let it sit over the weekend and now it will crank over but will not run. i was pumping the gas pedal to get it started, but that stopped working. Then i started using starter fluid and that worked for a while. Now all it will do is crank over. Most of the stuff the Factory Service Manual tells me to check says to start the car, but i cant. Can anyone tell me what i can try? I think it might be the CKP but i am not sure. I thought the ECU would tell me if the CKP was bad right? help please i need my car to get around. THANkS
