Factory service manual link
10speed
Saved a link on my Droid Turbo 2 screen for the Infiniti factory service manual,its been opening instantly through Adobe and Google pdf viewer until a couple days ago,now it says pdf format can't be viewed. Tried everything I know.Anyone else having a problem opening the service manuals?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to NICO!
Please note that our FSM is currently undergoing a revamp and you may experience a delay in viewing/downloading them.
10speed
I thought that might be the issue. Do you know how long it might take?
10speed
Thanks!
Rogue One wrote:Welcome to NICO!
Rogue One
2022 Honda Pilot SE
AZhitman wrote:Are you guys following the links from here?
http://www.nicoclub.com/archives/use-ni ... abase.html
All of the ones mentioned loaded fine - The early manuals take longer, since they're not broken up into chapters.
p.s. If you're using R-click, you're doing it wrong. ;)
10speed
Hi Rogue One ,I followed the link you provided for Infiniti FSM and I still get the message "Cannot display pdf" and it worked perfectly before. I tried to pm you from the mobile site,but it won't let me. Any advice? Thanks
Rogue One
2022 Honda Pilot SE
There may be a problem using a mobile device like a phone to access the pdf's that I'm unaware of. If you were using an actual computer, I'd simply recommend clearing your cache, history, etc. Come to think of it, have you tried accessing the files with a computer rather than your phone?
audtatious
They are no longer direct pdf links. Clicking on the PDF should launch it in a webpage.
10speed
No not yet, but the entire manual was instantly accessible until about a month ago from a bookmark on my android screen.
Rogue One wrote:There may be a problem using a mobile device like a phone to access the pdf's that I'm unaware of. If you were using an actual computer, I'd simply recommend clearing your cache, history, etc. Come to think of it, have you tried accessing the files with a computer rather than your phone?
10speed
I followed the service manual link on top of the forum page all the way through to the page with the individual fsm section abbreviations on the left side and still get " cannot display pdf,invalid format".Is anyone else having this problem? Thanks
audtatious wrote:They are no longer direct pdf links. Clicking on the PDF should launch it in a webpage.
10speed
Tried the link path on my other Android and it won't load either.
grambette
Car: 2020 Nissan Rogue SV
Are there any service manuals for a 2020 Rogue out there yet?
Rogue One
2022 Honda Pilot SE
grambette wrote:
Sun Sep 20, 2020 4:57 pm
Management is looking into updating the FSM section. Nissan North America (NNA) revamped their sections for manuals which has complicated matters, not to mention that we also have to pay to access them. Unfortunately there isn't a date yet on when this will be completed, so just keep checking.
If your need is urgent, you can pony up $19.99 and get a one day subscription to view the 2020 Nissan Rogue Service Manual online from NNA. Or for a mere $210.00 you can get a copy sent to you on CD.
In the meantime a lot of the info in the 2016 Rogue FSM will still apply to your car.
k9sar
Car: 2005 Nissan Pathfinder SE
2020 Nissan Rogue
Any update yet on a 2020 Rogue manual availability? I just bought a 2020 for my wife and want to be prepared if anything goes wrong.
In case of emergency, I have pulled the 2016 sections except for EM (engine mechanical), CL (clutch system), SCS (suspension control system) and EXL (exterior lighting) because apparently those sections are also unavailable on here (unless they don't follow the normal naming convention). I was able to pull a 2014 version of EM and EXL just in case.
Rogue One
2022 Honda Pilot SE
Unfortunately we can no longer update the FSM's. Nissan North America cut off access to ALL FSMs in 2015 -16. We were able to get partial ones for certain vehicles, but this was a corporate decision, so there's not much we can do about it. NNA changed the formatting on the FSM's so that they are no longer in a downloadable PDF format.
If you find that you do need the 2020 FSM, it is available from Nissan.
The Service Manuals used to be available on CD for $210.00 (USD), but it appears they've removed that option.
You can purchase an Online Subscription to view FSM's on their website:
  1. One Year Subscription $720.00
  2. 90 Day Subscription $225.00
  3. 30 Day Subscription $75.00
  4. One Day Subscription $19.99
k9sar
2020 Nissan Rogue
I thought I ran across an actual part number or document number for a 2020 ESM disk but can't locate it anymore. Does anyone have this identifier? I also read somewhere that it only worked in IE and none of the newer browsers. I'm trying to contact nissan directly to see if I can get my hands on one or have my dealership work on getting it since they promised me a FSM with my purchase. Maybe I'll stop into their world HQ in Yokohama on my next trip and ask there. ;)
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If the dealer promised you an FSM then they were talking out their butts, all the FSM's past '17 are online subscriptions. You should definitely take it up with Consumer Affairs, maybe you can get a lifetime free access at dealer expense.
