Word for word, I am with him on this.240kid wrote:well, dont forget that the ball joint does move, and the boot is mostly to keep dirt and moisture out of the joint, rather then contain and hold a supply of grease for the joint. IMO installing a grease fitting on somthing like that would be more trouble then it is worth, and you run a high risk of getting metal in the joint, which will do the opposite of what you want it to do
