Factory Rockford Fosgate subwoofer help.
Post all your Nissan electronics, car audio and stereo questions here!
chompsticks
Car: ???? Nissan Cube Krom
Hey guys, I was wondering if any one has had any luck hooking up the factory RF subwoofer to an aftermarket Apline head unit. A buddy and I have tried and all we keep getting is static through the sub. Any tips or info would be great! It is for a 2009 Cube, but I think the system is same for other models with the RF system.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
I've been looking around, but have yet to get my hands on a FSM that shows the wiring diagram on a Cube. As soon as there is one available, I'll look into it for you.
chompsticks
http://www.nissancubelife.com/...824.0
here we go, Thanks for looking into it for me.
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
The FSM is actually pretty useless in this case. All that I could get was that the turn on wire is identified as pin 46. You might be able to pick out a pair of wires that aren't being used that are shielded signal wires to the woofer. I'm not sure if you can get to the woofer itself, but it might be easier to pick out what wires are what there.
chompsticks
Alrighty, Thank you! I will let you know if that will work.
