Factory Nissan Rims on the Rogue
NicolesRogue
Car: 2008 Nissan Rogue S
I have been watching you guys post some great photochops, and I was looking into the idea of putting some New Maxima Rims on the Rogue, or Rims from New Altimas on the Rogue. I even saw some Infiniti Q sumthang with some nice rims. But I just cant imagine what they would look like on the Rogue. I have an Indigo Blue Rogue. Can anyone chop one up and give me a ruff idea of what it would look like? I seen someone posted a Rogue with Infiniti G35 rims I believe. That looked nice.
philipa_240sx
Venom_Rogue tried some Infiniti G35 wheels, there was one problem: The center caps on the front wheels would not fit due to the longer hub spindle/bolt:
zerothread/339212
Just about any Nissan/Infiniti wheel that has similar dimensions to stock should fit. The important info:
5x114.3mm bolt pattern+40mm offset
Any of the larger FWD Nissans should be a good fit ie. Altima, Maxima
Be careful of the Infiniti's as they use different offsets and different wheel sizes (Rear wheels are typically wider than the fronts). You want the same wheel and tire size at all 4 corners otherwise the VDC and AWD systems will likely start flashing error codes/warnings.
Do a search for 'Eddnog' and you will find many photos of his heavily modified Rogue including his aftermarket wheels.
Return to “Rogue Forum”
