factory jack wont budge
black g50
Car: 1994 Q45 Black/Black--235/40/18's avh3100 xplode 12" and amp 160000miles.2001 rodeo 190000miles
How the @#$% do you remove it???Iv'e tugged raised lowered smacked pushed cussed and it wont come out.Looks like it's never been used.
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Usually, you just loosen the jack by pulled it out after turning it a few times. The square head with the holes...?
black g50
Turned back and forth,can see it go up n down,but wont come out.Like i said it looks like it's never been used.even had my 260lb,friend try to muscle it out...nope.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Grease and lots of it. White lithium grease in a spray can!
yodawill2000
Car: 94 Infiniti J30
Or penetrating oil! IE:WD40
black g50
I can get it to wiggle a few mill,but it seems like it's locked on something.
GSUjinih
Car: 1993 240SX Coupe
1993 240SX Vert
1994 Q45
I just took my jack out for the first time since owning the car. Make sure to turn counterclockwise to lower. I had to use some good force to get that initial turn. I just wiggled it until it came out. I might put some grease in there to make it easier next time. Does anybody know what that tube back there connects to and its function? It came loose when wrestling with the jack!
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
You're probably referring to the drain tube for your moonroof. It is very important that does not leak into the car - reseat it and run water (carefully) into your moonroof wells to test for leaks.
GSUjinih
1993 240SX Vert
1994 Q45
paranoidjack wrote:You're probably referring to the drain tube for your moonroof. It is very important that does not leak into the car - reseat it and run water (carefully) into your moonroof wells to test for leaks.
Thanks for the tip, as it was raining pretty hard today and I fixed it this morning.
OZQ45
Car: 1993 Nissan Infiniti
black g50 wrote:How the @#$% do you remove it???Iv'e tugged raised lowered smacked pushed cussed and it wont come out.Looks like it's never been used.
Try turning the top of the jack - the portion that pivots and fits over the body seam - so that it points across the car instead of along it. That way when you lift the back you get a few extra mm clearance and it should come out easy. I too swore at it for the first couple of times until I worked that one out. Wouldn't it have been so much easier for them to add just a little extra clearance!
black g50
I'll try it out OZ.
