If you follow justeller's horn-location link, you'll see I found the horns where JCPark indicated, not where the FSM diagram says they're located in the bottom center area. I was able to access the stock horns without removing the bumper by unfastening the plastic inner fender & under shields, but I have small hands. I considered several types, including the twin Hella's, but decided to go with a Stebel Nautilus Motorcycle Air Horn. It's rated @ 139db, 530hz @ 12v & that's plenty loud if it's wired correctly. I'm old head-old school & went with the chrome to complement my polished aluminum billet grille it sits directly behind. The plain black is $20 cheaper. I also considered fabricating my own wiring, but decided to spend another $20 on a Universal Plug & Play Wiring Harness, & it was well worth it. It's a complete kit including relay, connectors & fuse, with clear instructions. Following them, I only had to unplug the wire from 1 horn (the one on the battery side), & plug it in. The remaining passenger-side horn beeps only when the door-lock fob is pressed. The A/M horn needs to be in parallel with the remaining OEM one, not in series or they'll not draw current properly, honk together & sound like a dying duck.
http://s354.photobucket.com/user/KenZmi ... c.jpg.html Good luck!
