AltimaSkillz333 wrote:Has anyone changed their factory HID's to a brighter aftermarket HID??whats the process??
i think your syntax is off a bit... when folks mention brighter, they are usually talking about lumens when it comes to light... however, the 4300K factory HID bulbs emit about 3200 lumens... which provides the bightest light output.
Changing the temperature up or down from the fatcory 4300K will actually produce less light!
SmokeDaT wrote:
You don't need to get 55w bulbs. 35w is fine. More wattage doesn't mean more light output.
that's not true... 55watt ballasts and bulbs in the same color will be brighter than 35 watt ballasts and HIDs. , but they will also draw more current from your electrical system...
so to the OP, if you want the brightest light output, as phobs stated, you will need to get aftermarket 55watt ballasts and 44watt bulbs , but keep the bulb 4300K... if you want "whiter" light, then you can go with 5000K! just remember that in terms of lumens or brighteness, 4300K will give you the most light output!
