:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Tue Apr 27, 2004 3:23 pm
My only comment would be that TPS is directly related to the timing control in that it MUST be unplugged to set the base timing correctly.
Without it plugged in the ECU's feedback and timing control is interupted...
And you guys need to realize that the KA ECU is a little more complicated than the SR or VG ECU...the guy referenced on that page, Ash, was a a local guy, and a good friend of mine. He did the "Zimulator", which was the basis for som eof the other programs...basically allowed you to ROM tune on the fly.
And he couldn't even copy my JWT chip to evaluate it - IIRC, the SR and VG use 256k, 32 pin chips...and the KA uses a 1meg, 40 pin chip that is more expensive and contains more data.
Now, this could be due to the OBD stuff included in S14 ECUs, but nonetheless, throttle position plays a major role in S14 tuning from what I can tell...
As proof, I offer my S14 KA-T dyno with the TPS unplugged - The A/F, that were at ~12.X on the previous pull, stayed at 14 or above, even at WOT...I of course let off at ~3500, but it shows that it's used for fuel tuning somehow, and most likely timing as demonstrated above.
Now, does this hold true for S13s...maybe not.
So, food for thought... - Brian
