Factory Car Jack worthless
oohowieoo
Car: 2010 Nissan Rogue SL AWD
After a long day at work, I'm leaving around 1:30am to get to my Rogue. After finding that my front right tire was flat I proceeded to place the spare on. At first look of the rink a dink factory car jack i questioned whether it will hold up the weight of my car and jack it up high enough with it being an SUV. Thought to myself, it has to since I don't believe Nissan will ever put this here if it didn't. After jacking the car 3/4's of the way up I was able to take the tire off. When I went to grab the spare and started to put it on, the jack quietly started bending and next thing I knew the car had shifted off the jack and was laid on it's rotor. I could have got crushed? I'm thankful I didn't but it was apparent to me that whether it be just Nissan or all other car companies, they really should include something that is a lot safer to use. If I was able to purchase a SUV hydraulic jack on Amazon for $70 just now, it's something that should be included with the car. Thinking about complaining to Nissan Dept. Is it worth it?
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
Yeah I hear you on that one and I'm sorry to hear about your terrible experience.
I've never actually had a jack deform/bend and fail under normal weight of the vehicle it was designed to be used with. I know it is common for them to tip a the base is very narrow and unstable, which is a real concern and easily fixed with a proper stable jack, but the fact that your jack failed structurally is even more shocking. If you have the time and desire to complain to Nissan it definately wouldn't be a bad idea, most often things like this go un-reported simply because people don't take the time to complain and let manufacturers know that this is not acceptable. I agree something like this should not happen due to cost cutting at the expense of safety - in my experience all manufacturer's seem to do it, but again that does not excuse it.
hgclim
oohowieoo wrote:If I was able to purchase a SUV hydraulic jack on Amazon for $70 just now, it's something that should be included with the car. Thinking about complaining to Nissan Dept. Is it worth it?
Which jack did you get from Amazon? Are you referring to a jack that can fit in the existing location where the factory jack is stored?
Return to “Rogue Forum”
