Qxxx4 »
https://forums.nicoclub.com/qxxx4-u85589.html
Thu Dec 25, 2008 6:02 am
WHAT! man its right on your factory wiring harness! one of the pins on the connector is for your factory amp turn on. This is probably the third time ive said this on the forum, seeing as how your thread was to the point, here is a screenshot for everyones reference!
remember..your looking at the mating end of the connector. and the "blue/blue+white" wire is on the Aftermarket harness that connects to the factory harness from the aftermarket deck, i forget what colour it was on the factory harness...but follow this pinout and youll be fine. You can also wire your subwoofer amp remote turn on to this wire, I did and it works flawlessly, both amps turn on at the same time
good luck!
