MaineExport »
https://forums.nicoclub.com/maineexport-u157.html
Mon Dec 16, 2002 2:17 pm
START FROM SCRATCH!!!!!!!!!!!!
There is nothing worse than using factory wiring, especially after a previous owner has frigged with it.
From the head-unit.... run wires to all four speakers. This is VERY easy, but a little time consuming. Then YOU will know for sure, exactly what color is what. This will not only elimiate the confusion, but you will have better wiring and you will have bypassed the factory amps! They are junk anyway.
I also think that you erroniously assumed te wire colors were what you stated. Just get rid of the whole mess and wire it yourself.
You will need about 25 feet of speaker wire, and it doesn't hurt to rewire the power supplies and ground with some new gear.
BTW...... PLEASE use punctuation.... your post is almost impossible to read. You don't have to be perfect (we all know I'm not), but it makes it much easier for the READER to understand what you are saying.
