factory alarm problems. please help!!!
esahuque
Car: 95 240sx KA-T, 04 frontier
please help I bought my 95 240sx se without an alarm pad. I never had any problems. now the alarm keeps going off for no reason and kills the ignition, stranding me. how can i bypass or disable the factory alarm?
esahuque
doesn't anyone know how to disable or bypass the factory alarm? please, it keeps going off and leaving me stuck plus someone's going to get my car towed if this keeps up. there's got to be a way to terminate it for GOOD.
s13sr20chris
yeah, its not hard. you have to trace every single wire from the alarm back to where it goes on the vehicle harness. once you find the wires that are on the ign cyl, cut them and reconnect them without the alarm in the way. once this is done you should be able to start the car. then you can rip out all the other garbage at your leisure.
s13sr20chris
ooops, just realized you are talking about a factory alarm. thats complicated. you MAY be able to but you will need a wiring diagram and some creativity.
esahuque
Can u help in any way. I'm willing to cut, splice, run new wires, what ever it takes. where can i get the wire diagram from? thanks for your help.
s13sr20chris
ok, it is actually looking easier than i thought. remove theft warning relay #2 and install jumper wire or solder wires together from terminals 3 to 4. one wire is orange and one is black with a red stripe.that will allow the car to start with the theft warning sys bypassed.now we need to make it stop going off.
here is the location of the relay(s)
s13sr20chris
ok, to disarm the alarm i think you can just unplug the hood switch. do you see the hood switch in the little picture above? it says hood switch next to it. it has a two wire connector on it. its prob gray and rounded. unplug that and see if the theft warning sys ever comes on. it shouldnt.
esahuque
thanks for the help. i'll try it today and see what it does. thanks for your time.
esahuque
one more question. do i leave the hood switch unplugged or just unplug it and then plug it back in?
s13sr20chris
leave it unplugged. that should keep the alarm from ever arming. you may not have to mess with the theft warning relay if the alarm never arms.
