Factory Alarm - Mind of its own.
My mom woke me up today to tell me that the alarm on my car was going off... intermittently. It would start honking, then stop, then start after a half hour or so, then stop. Wonder if its been doing that all night...
Any ideas on the cause? I got out of bed, started the car, and everything seemed okay. So I shut the door and locked it. Its been fine for an hour now.
-Jesda
oxs1
I have the same problem. I think it might be the sensors. I remember it going off for no apparent reason like 3 different times.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Try undoing the battery..... I think that should help...
cweberj30t
Car: 1993 J30t
2003 G35
2007 G35X
2011 G37X
Mine did that one night when it was extremely windy. It could be the sensors picking up the wind.
Alan
Car: Cars, cars, scooters
I had this problem on our '92 Q about a week after we got the car. Someone on the board suggested I adjust the sensor under the hood. That fixed it! So I would start there. Now if the problem is on a Buick, I don't know what to suggest.Cheers, Alan
Where is this sensor? And yeah, its been really windy and rainy here lately.
elwesso
2007 BMW M Coupe
THe sensor is on the drivers side near the airbox. Its obvious... Its mounted on the strut tower.
I suppose adjust it higher...
Found it! And found the cause. At the meet, Fred warned me about my hood not opening/closing very well and potentially causing some damage.
So there's a little arc/bend in the hood. I sprayed the hinges with WD-40 and bent the hood back by hand. All is well.
-Jesda
Rex
Car: None
I still think simply disconnecting the battery will prevent it from going off.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
It could have been honking Morse code, for "fix my chain guides"
elwesso
2007 BMW M Coupe
LOL!!!!!!!
you can almost see the car in his sig picture, saying "yes, listen to the idiot with the sign. Im sad!"
90Q45blue
Car: 2006 Honda Accord EX-L
LOL.
Q451990
elwesso wrote:THe sensor is on the drivers side near the airbox. Its obvious... Its mounted on the strut tower.
You mean the hood switch? The one with the rubber accordian boot? A good check is to just unplug it - it's normally open and closes when the hood is opened.
Heath
elwesso wrote:LOL!!!!!!!
Jeff Williams wrote:It could have been honking Morse code, for "fix my chain guides"
LOL!!!!!!!!!!! :rotflmao
