HOST »
https://forums.nicoclub.com/host-u90780.html
Sun Jan 03, 2010 4:39 pm
Ok, apparently no one knows of a solution to this problem. I, however.. have found one! If you have an aftermarket alarm system (such as a Viper) hooked up without your factory alarm disabled, it causes problems.. I had to press the unlock button and turn the key to unlock the door TWICE in order to get in the vehicle.
Why twice? Because the ECU detects TWO alarm systems, thus turning it twice disables both (manually) so that you can get in the car. Not THAT bad if the fob doesn't have issues (which mine did, it was old school Viper lol), just a waste of time and an inconvenience. So basically you have to disarm with the fob, then turn the key twice (unlocking twice) to get in. stupid, I know.
SO.. today I had planned on doing real work to my car but I couldn't because the alarm systems wouldn't stand for it. Had to disable the Viper system (which I did last night) and just found out that with the factory alarm still activated, and since I didn't disconnect the battery (which I recommend doing anytime you do any type of electrical maintenance/upgrading etc) when I slaughtered the Viper alarm the ECU still reads that there are two alarms, so once I disconnect the battery and allow the ECU to reset (has to be disconnected for about half an hour) the system will read only ONE alarm system (factory alarm) like it's suppose to, and then you will only have to turn the key once which is normal, to disable the factory alarm.
Now, the moral of this story kids is to have your aftermarket alarm systems installed by PROFESSIONALS if you don't fully understand how to do it yourself because epic situations like this can occur if you do not. Factory alarms must be deleted first before afermarket alarms can be installed. I'm glad that I figured this all out with the help of my buddy, so that I can still have an alarm instead of welcoming thieves to a red light special.. because I was EXTREMELY close to ripping out anything and EVERYTHING alarm related!
I hope this helps anyone else in this situation.. I've searched Google for days and found nothing, and apparently not a lot of people here have gone through this.. so.. there ya go!
