f50 wheel question
johnjohn007
Car: 2002 infinfit Q45 -1991 honda civic-1995 acura integra
Does anybody know if this size wheels will for properly on my 2002 Q45? 20in 5x114.3 with offset of 38?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Its around an 8in width (either 7.5, 8, or 8.5) it should be fine...
Q45tech
Obviously you must select a wheel with the correct hub bore [66mm] or secure metal adapter rings for each wheel.
elwesso
2007 BMW M Coupe
Tech, do you REALLY think that you need the hubcentric rings?
Reason I ask, is that the hub does not bear any load on the wheel, rather it just centers the lug nuts..
my wheels are not hubcentric, and all I do is tighten the wheels unladen and in stages.. Like tighten 2 lugs just so they're engaged, and then put the rest on, torque, then torque again with the wheels on the ground.
Ultimately, the goal is that the lugs are centered about the lug nuts, and as long as you're careful in torquing the wheels, that should be good enough?
also Tech, might take a gander at my thread in the wheel/tire forum...
