f50 tire presure sensors
xerexabante
Car: '02 Infiniti Q45
'02 Nissan Maxima SE
i check my tire pressure which tire is which? there are 4 lines
__________32
__________32
__________31
__________32
which tire is 31?
mcrews
Car: 2002 Q45 Sport
The 02 F50 tire sensors are not specific to a location.right now, the top 2 are my rears and the bottom 2 are on front.When I rotate, they change.also fyi, when you put the spare down they all seem to go blank.
mark
xerexabante
thank you for the input. seeems like i have to a test to figure this one out. i might have to pump 1 tire at a time higher vto see which 1 is which.
StarPD
Car: 2005 Q45
xerexabante wrote:thank you for the input. seeems like i have to a test to figure this one out. i might have to pump 1 tire at a time higher vto see which 1 is which.
That is the correct procedure for determining which tire is displayed. Overinflate one tire at a time and note where it is on your display, then make sure they are all re-set correctly.
FWIW, if you have a flat repair or any work done on your tires/wheels, make sure the shop is familiar with tire pressure sensors and knows how to protect them when breaking the bead on the tire. They are easily damaged, and expensive.
Also, when any aluminum wheels is removed and re-installed, be sure to have the lug nuts re-torqued in a star pattern after around 100 miles.
