StarPD »
https://forums.nicoclub.com/starpd-u54244.html
Fri Nov 30, 2007 7:18 am
Dennis, I know you are well versed on handling problems and solutions for G50s, but I've seen little from you on F50s. Maybe for myself and other F50 owners, you could do some research and study of F50s to ameliorate some of their inherent shortcomings.
One is the exaggerated understeer. Usually, that is improved by going to a thicker rear sway bar, and firming up the sway bar bushings with replacement bushings or shims to tighten the linkage. I understand however that there are no alternate sway bars for F50s, and that the method of attachment doesn't use bushings at the ends which can be firmed up to improve handling response. It seems that only having a new thicker sway bar made by a spring shop would answer this. That's a bushel of snakes itself though, not only for the expense, but I understand that all new attachments would be required, both for the bar mounting and for the ends. Getting everything right might be a challenge. If that is the ONLY solution, how should we determine how thick a new sway bar should be?
I have found that turning the VDC off reduces the understeer, but not enough to make the car dig into the turns like my '94 "t" model with "HICAS. That car handled like a sports car, and had just the right amount of slight oversteer to allow excellent control going into and through a curve. Still, turning off the VDC every time one goes into a curve, or even every time starting the car is a PITA, and I'd like to make handling more neutral at least.
The second is steering. My '05 Q45 doesn't track well, even though it wears 245/45Z18 Bridgestone RE050A "Pole Position" tires on 18" x 8" aluminum wheels with the correct offset. I run 34.5 psi tire pressure, as it seems to be the best compromise between ride and handling. As you know, the F50 has no provisions for adjusting caster. That would probably help tracking at least, but alas, there's no no way to do that that I can find.
Further, steering is vague, perhaps overboosted, and with little feedback.I investigated tightening up the rack mounting and perhaps steering linkage connections, but am told there is no way to do either. I suspect that steering boost is controlled electronically, so it appears that some sort of mods to one or more of the computers might be necessary. That would be complicated I think though, as so many of the computers are interdependent on each other, and affect each other.
Dennis, I know that you are THE Q45 guru, and know more about them than anyone. I am also aware that there are a lot more G50s around, and a lot more G50 owners in this forum than F50s, but we F50 owners are Q45 guys too, and we need help. What might I do to persuade you to get an F50 on a lift and examine the rear suspension and steering systems to find a way to improve them as you've done for the G50?
I dearly love my '05 Q45, and would like to improve these deficiencies so I can enjoy it more fully.
Will you help?
Thanks.
