q45p wrote:what do you get in city on miles?
I do about a 50/50 mix of freeway and surface street driving, very little in rush hour traffic in Phoenix AZ.
My '94 Q45t got anywhere from 18.5 to 22 mpg in this situation. Highway fuel mileqage was astounding, 25 5o 28 mpg at 65-75 mph. It didn't burn a drop of oil between 3500 mile changes.
My new to me 2005 Q45 is lucky to get 16.5 to 18 mpg in the same city driving, and 20 to 21.5 on the higway. It appears to be using around1/4 to 1/3 quart of oil per 1,000 miles. It has 24k miles on it, and I use Mobil 1 "Extended Service" 5 w 30 synthetic oil and factory filter.
The '94 did have timing bumped to 15 degrees BTDC, which helped fuel mileage and performance. I'm trying to get the timing bumped by 2 or 3 degrees from factory 12 degrees to 14 or 15 degrees BTDC on my 2005, but my dealer says it can't be done, although a member here advises that it CAN be done with a CONSULT II. I'm investigating that right now, and will report on whatever I find in a separate new thread when I have answers.
Anyone else have comments either way, or personal experience with ignition timing on F50?
