maxnix wrote:If you go with the big brembo or AP Racing, the question is what do you put on the rear to maintain balance?
For a cold initial stop like common in street driving, the OEM formulation is the best. If you are going to autocross, then a harder pad will work better once the brakes are warm.
I find that the OEM Brembo replacement rotors, especially the plated and drilled ones Stillen sells (and which Joe features on special occasionally) work so well with OEM pads that I haven't had any further thoughts on a true upgrade. Now if I lived in the mountains, autocrossed or drove in Nevada, that might change. The Brembo rotors seem to maintian uniformity at least 3 or 4 times as long as OEM.
I talked to an brake systems engineer, and he confirmed that the Brembo Gran Turismo don't really change the brake biasing as the combined areas of the pistons in the Brembo Caliper is not much larger than the OEM calipers' piston area. He also told me that rotor size does not affect bias as much as the pad friction material. Brembo claims that their GT kits are compatible with the factory rear brakes and ABS/TCS/ect.
If you really wanted a BBK, Rotora would be good choice as they are well made and not as expensive as the Brembo. They also offer a rear kit that Brembo does not for the F50.
You may be able to look into the G37 brakes as it apparently fits the Y50 M35/45 with not modification. Look on the M35/45 forum. May not fit the F50 then you will need custom brackets tho the rotors should not require any mods as they use the same bolt pattern and hub bore. I would have to look at the rotor offset tho. As of this time, I don't know of anyone that has tried putting these on the F50/Y34 yet.
http://g35driver.com/forums/br....html
http://cgi.ebay.com/ebaymotors...ZWDVW
I had a custom made kit for the rear using Brembo parts.
If I were to do this again, I would go with Rotora as it would have cost a bit less and a bit bigger rotors/calipers. Tho I do like Brembo and their reputation.
