F18X8.5 and R18x9.5 for a S13
N.O. Accorderz
F18X8.5 and R18x9.5 offset is +35 this is for a s13would i have clearence problem with my coilovers? i'm also using stock brakes for now. do i need streched tires to clear the fender?
SmithSR
Car: 240sx
8.5" +35 will hit the front coilover.
8" +35 can only be used with 215 width. And that's only with the spring perch set just above the tire's shoulder. The can't be ultimately low for this to work. I used 215/45-17 for perfect oem overall diameter, and excellent tire selection.
N.O. Accorderz
they are 18s...i'm think that i have to run a 225/35/18 and 10mm spacer in front?
18x9.5 in the rear should fit fine right?
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
do you have a jet engine under the hood? why would you want such a wide tire/wheel in the rear?
chmercer
if the wheel hits the coil, just dial in some positive camber
N.O. Accorderz
i can only dail in so much +camber...i guess i have to wait till i get some wide fenders
yes but its actually in my hatch dumbass, go somewhere else with your bs.
emperor_lunchbox wrote:do you have a jet engine under the hood? why would you want such a wide tire/wheel in the rear?
toledo240
what tire would you run on a 9.5 that fit with that offset? would you have to stretch 225's. will 8.5 fit if you just had agx's
