F!!!! the quest alt< almost direct bolt on .... 110amp
SIL-LINE
Car: S-13 With RB20det
ok guys im not done with the whole thing but so far so good ..
i got the alternator from an infinity qx4 . its a 110 amp.it bots up with the original bolt and spacer ..lines up perfectly with the belt, all thats needed is a bracket from original tention placement bolt to about an inch lower. thats alll!!!!!!!!!!!!!
Woooo Hooooo.......
placement of tentioner bolt ..
original bolt and part #
craz4240
Car: 1995 240sx w/rb20det
What year QX4 is this from???? I can get these remanned on the cheap.
Lozer
Car: vroom vroom hissssss *POP "awww s***"
details.
year ??????
craz4240
I only ask because I have 2 listings for 110amp alternators, the 200-2001 and 2001-2003. Ones cheap and ones 3 times as much.
SIL-LINE
INFINITI QX4 3.3L 1998-2000 ALTERNATOR .
i researched the part number and i got 110 amp.
but i just researched it again , and it says it varies from 100-120.
RustspecS13
Car: '74 260z and '88 300zx turbo
I have a Quest Alt and I did exactly what you did.
I don't know why every one freaks out about it. I did have the clearance the alt case so the stock bolt and spacer would fit but its really easy.
BTW, The Qx4 uses a VG33E, just like the quest, So its most likely the same alt any way :P
~Alex
craz4240
Yeah I have that one listed as 100amp the VQ35 one is 110 amp,I may bring one down here just to put it up against my quest and stock alt.
SIL-LINE
Ok , i just finished the alternator .
It charges at 14.9 -15.0 volts and my HID's never looked so bright .
As far as getting it bolted down , I just took out the tention braket , cut off the top bolt hole 1/4" from hole . made a hole by eye about 1/4" from edge of where i cut top hole . Put braket on bottom water pump bolt < angled it down and ran the same STOCK setup to tention it. Same belt and all!!!!!!!
Im not so sure on how much amp the alt has but definately an upgrade.
Nice work!
Pet peeve: TENSION, not tention. The "TENSION" bracket keeps the alternator TENSE.
I see people do this with SUSPENTION, and TRANSMITION... Getting it right helps others who are searching for info find what they need.
SIL-LINE
LOL...
Yeah , Excited about gettin this down on the boards. And just realized that i did it on the previous posts too.
thanks
