slownslurious »
https://forums.nicoclub.com/slownslurious-u29303.html
Sat Mar 03, 2007 10:31 am
spl parts has everything you need to maintain an OS giken clutch...the discs are usually $90-$110 each, depending on size and composition. Some of them are considerably more (like the carbon ones in particular). Only thing you have to worry about is the manufacture date... OSG updates its designed but keeps the same partnumbers, so if you order a part with the same partnumber there is a chance it might not fit (ran into that with the crush sleeve for the Z32 clutch I have).
