f/s ca18det ST.LOUIS!!!!!!!!!!!!!!!!!
dsc4130
well im doing something i thought id never do, im going sr my car seems to play musical motors. the reason im doiing this is because the sr just kinda fell into my lap. i just rebuilt this motor 300miles ago so its on its second oil change and will need further break in time. the transmission shifts well adn the motor runs like a champ. the turbo has a bit of shaft play but will last a while if your easy on it like i was.ohh and im a little parinod and i always think my motors have rod knocks so im going to include a full set of new bearing to go with it
- this motor has a full stock oem rebuild that means that the pistons have been out of the block - it has perfect circle ring and clevitte77 bearings- has all nissan oem gaskets beside a cometic metal head gasket(1.2mm)- the harness,although was wired by me, was done the way that heavy throttle said to do it. it will need a new lower harness -the head has all new valve stem seals, and was cleaned and decked-the block was hot tanked, decked honed and the water neck was fixed.other than that please feel free to ask me questions, heres some photosim looking for $1600...... btw the intercooler doesnt come with it
kapower06
how much will you sell the i/c for with the piping and mounts? And were the only two people in the Lou that have ca18's yet we've never met?
I may have a friend that will buy your swap....
dsc4130
kapower06 wrote:how much will you sell the i/c for with the piping and mounts?
$250 and ill install it, ill even throw in my electic fans if you need them
kapower06 wrote: And were the only two people in the Lou that have ca18's yet we've never met?
your more than welome to come over and hang out at my dads store anytime. im there almost everyday at some point. call me at 314 616 9274
lilskyline240
Car: 90 240sx w/ rb30det
posted on your other for sale thread
dsc4130
ran into an ecu problem $1100, i need this gone. im moving to chicago in a month and i cant keep it
