No offence man, but that's a weak gun. You need like 500ft.lbs gun+ and a nice plentiful air supply to do these big crank bolts.jedijeff123 wrote:well i was using a 260ft-lb Husky impact wrench. but the breaker bar with a screwdriver jammed into the flywheel worked! now to just get my pulley puller aligned...looks like more PB Blaster!
Indeed. I got my 850lb-ft forward, 900lb-ft reverse impact from northern tools for $100 with a 2 year replacement warranty. Price isn't too bad for a decent one.robomatic12 wrote: No offence man, but that's a weak gun. You need like 500ft.lbs gun+ and a nice plentiful air supply to do these big crank bolts.
huh didn't know antisieze causes bolts to magically come loose, thought it only prevented it from seizing. Hmm, how stupid of me.jedijeff123 wrote: no antisieze, sounded stupid for a bolt that's constantly spinning
lol. Enlighten me.Oh Em Zee wrote:anti-seize + torque wrench = impending failure.
fixedOh Em Zee wrote:anti-seize + torque wrench - knowledge of anti-seize's effects on torque values = impending failure.
I never had to do that. A little leverage and patience always worked for me.tg wrote:The bolt is the easy partGood luck.
dude we had a mechanic and an engineer on it... we both thought it was welded on 'cause it was such acunt to get off... honestly we broke off the bolt in the first hole (you can see it there) that's how well it was on there.Rare_f8 wrote:I never had to do that. A little leverage and patience always worked for me.tg wrote:The bolt is the easy partGood luck.
The fubar VG that came out of my car. The crank counterweight got so bent that it locked itself into the block. It wasn't easy to get that timing drive gear out. I ended up spraying underneath the gear with lube and tapping the face of the gear down on to the shaft, then lifting it with leverage, and repeating. Once it got easier, it came out.tg wrote: dude we had a mechanic and an engineer on it... we both thought it was welded on 'cause it was such acunt to get off... honestly we broke off the bolt in the first hole (you can see it there) that's how well it was on there.
Anyways, that bolt shouldn't be that hard... get a 1/2" ratchet on it with a proper socket (not an impact socket) and then stick a 3ft bar on the end of the ratchet, bingo. Make sure somebody is preventing the crank from moving.
Yeah the key in this setup made it hard to 'wiggle it' as it could only move outwards and we couldn't get anything substantial behind it that wouldn't bend. Live and learn! I think it was due to sitting for so long, it had actually rust welded itself on there.Rare_f8 wrote:The fubar VG that came out of my car. The crank counterweight got so bent that it locked itself into the block. It wasn't easy to get that timing drive gear out. I ended up spraying underneath the gear with lube and tapping the face of the gear down on to the shaft, then lifting it with leverage, and repeating. Once it got easier, it came out.tg wrote: dude we had a mechanic and an engineer on it... we both thought it was welded on 'cause it was such acunt to get off... honestly we broke off the bolt in the first hole (you can see it there) that's how well it was on there.
Did you put clamps on it along with the sealant? It shouldn't be leaking from the block if you just changed everything... It's fairly easy to see where its coming from... take the fan blade and fan shroud off, remove the upper timing belt cover and run the engine for a bit (not more than 2-3 minutes if its warm) and you should be able to see exactly where it's leaking from. Likely it's the short standoff tubes that come off the block.jedijeff123 wrote:ok, well i put everything back together and it looks like i have a leak from the radiator hardpipes...could it be that i used Permatex Thermostat and Water Pump sealant instead of Ultra Blue?? it was only about an hour between putting the hardpipes back on and filling it up...i didn't start the car i was just filling the radiator. it looks like it was the hardpipes because i could see coolant on top of the water pump, rathers than coming from underneath it......
